4 members (ndkid275, Hush, frogfarmer, BillCollins), 101 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#856108 06/03/2012 4:25 AM
I am trying to help a friend with the electrical system on his '53 chevy truck.
System is 12v and everything seems to be working fine but when he leaves his truck park over night the battery gets drained and is completely dead the next morning.
I helped him check all connections and everything seems fine.
Any advice?
might be a defective battery, have you had it load tested? does it have a modern radio with an 'always on' memory? .... put a meter in line on the battery + terminal, when you see current flowing, start disconnecting things until the current stops
By 'meter' Red59 means ampmeter. If a meter is not available I like to use a test lamp (looks like an icepick with a lamp or bulb in the handle and a wire pigtail hanging out). A couple of bucks at your FLAPS. I prefer to pull the neg. battery cable off (either side will work). Clip the pigtail wire to the cable and icepick point to battery post. With everything electrical off on the truck, the lamp should not 'burn'. If it glows, do as Red58 suggest, start pulling fuses.
Left my dome light on once....and once was enough!
Ed
Ed,
I did the same thing last year. Charged the battery twice before I figured out my dome light was on - noticed it when I went out at night to disconnect the charger. dang
