7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 126 guests, and 1 robot.
Topics128,056
Posts1,055,799
#856038 06/02/2012 11:16 PM
Would an 85 S10 with a 5-speed (apparently it was a 2.8) be a good candidate for a 1/2 ton AD tranny/rear end swap?
Wrinkle: It might be a S-15 as it apparently is a 4x4. Seller is unclear.
A 1985 would be the one you want as it will be set up for a speedo cable. The 4X4 part is not so good.
My Blog
So the 4x4 part is bad?
The rear is all wrong. Made to bolt to a transfer case, not a drive line.
My Blog
Oh well...Not sure if it is a 4X4, if it is I will pass.
The S15 would be the GMC version, rather than the 4x4. the 4x4 would be a T10/15.
Bill Burmeister
Looks like it is a S-10 4x4. Hard to get info from the seller.
I take it it is still a no-go.
Currently installing T5 from S-10 in 57 with 235. A learning experience. If it's FWD forget it. Must be pickup for shifter to be in right place. If it's newer than 89, probably has electronic speedo. If you're installing modern gauges, no problem. If your speedo is mechanical, it's a big problem. There are world class and non-world class trannys. Drive shaft must be shortened for my 3100. Didn't want to mess with original. Finding the right S-10 shaft is still in progress.Google will get you some good info. Try www.waywardgarage.com Hope this helps.
