0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Would an 85 S10 with a 5-speed (apparently it was a 2.8) be a good candidate for a 1/2 ton AD tranny/rear end swap?
Wrinkle: It might be a S-15 as it apparently is a 4x4. Seller is unclear. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1985 would be the one you want as it will be set up for a speedo cable. The 4X4 part is not so good.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The rear is all wrong. Made to bolt to a transfer case, not a drive line.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Oh well...Not sure if it is a 4X4, if it is I will pass. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The S15 would be the GMC version, rather than the 4x4. the 4x4 would be a T10/15.
Bill Burmeister | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Looks like it is a S-10 4x4. Hard to get info from the seller.
I take it it is still a no-go.
| | | | | Joined: Dec 2006 Posts: 12 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 12 | Currently installing T5 from S-10 in 57 with 235. A learning experience. If it's FWD forget it. Must be pickup for shifter to be in right place. If it's newer than 89, probably has electronic speedo. If you're installing modern gauges, no problem. If your speedo is mechanical, it's a big problem. There are world class and non-world class trannys. Drive shaft must be shortened for my 3100. Didn't want to mess with original. Finding the right S-10 shaft is still in progress.Google will get you some good info. Try www.waywardgarage.com Hope this helps. | | |
