3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#856048 06/03/2012 12:22 AM
due to a reason i would rather not explain. the crankshaft pulley (harmonic balancer) on my 55ist series 235 has pulled away from the engine about an inch, thus making the fan blade hit the lower pulley. what would be the procedure the get the pulley shaft in more to match up with the upper pulley? thanks, jim
gmman4 #856058 06/03/2012 1:55 AM
Driving a balancer on with the engine in place can be a challenge.
You may have a hard time on a 55 1st as it has the bull noise grill in the middle. If you can get a long rod out through the grill even at some angle it will help to install and tighten two 3/8" coarse bolts in the holes used for pulling the balancer. These bolts will lock out the deadening effect of the balancer making it easier to drive on. Once on be sure to remove the bolts.
My Blog
