0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Gimme a break - it's my first engine build! <…VIDEO…> | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Mark, Your engine looks good & I enjoyed your Blog. One question. What color & brand of paint did you use on the engine? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hey, I'm as stoked as your are. I should be running my pump tomorrow, here's hoping it goes as well as yours did...  Vince | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Mark, Your engine looks good & I enjoyed your Blog. One question. What color & brand of paint did you use on the engine? Thanks, Harold Thanks Harold - it's the Dark Grey that the Filling Station sells. Ultimately its a PPG Acrylic Enamel. Hey, I'm as stoked as your are. I should be running my pump tomorrow, here's hoping it goes as well as yours did... I was a bit nervous at first - I didn't get pressure for about 30 seconds of running the drill at a low speed, so I cranked it up a little and I felt the load on the drill almost instantly as Truckernix had described to me. Even better, this morning I ran out to check of the sitting oil had leaked from the timing cover and it hadn't. Fewf! | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Great job on your engine, and the dump bed on the truck is to cool. I could use a dump ned on my truck to help unload round bales | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hey Mark,
Are you going to leave the oil in the motor when you lift to install? Also, what did you use to prime the pump?
Thanks! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Hey Mark,
Thanks! When I rebuilt my distributor I choose the best parts out of 3 dizzy's I had acquired. So as it had been suggested by others, I took one of the spare shafts and used it. (with the gear removed!) <Dizzy Parts> Failing this, I would of used a big flat head screwdriver with its handle cut off. The advantage of the dizzy shaft is that it fits perfectly. Yes I plan to leave the oil in - I don't see a reason to drain it - the engine will stay pretty much level as I reinstall it as will be installed onto the naked frame, no cab. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Great job on your engine, and the dump bed on the truck is to cool. I could use a dump ned on my truck to help unload round bales Thanks! That acrylic enamel paint goes on very nicely - Although I did sand parts of my valve cover back down to bare metal and repaint. I wasn't happy with some of the ridges I could see from the old paint not being feathered away enough. The dump bed is what sold me on this truck when I first found it! Not that I ever plan on using it! | | | | | Joined: May 2012 Posts: 89 Shop Shark | | Shop Shark Joined: May 2012 Posts: 89 | I'm jealous! That's amazing, I'm glad you didn't run into the timing cover leak that I did when I primed it. Looks flawless, bet you can't wait to get er' fired up and purring! | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks! I'm working hard to make that happen this weekend. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | That is an excellent video demonstrating how that process should be done. Great work!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
