1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
i have an old gmc vin?? AFR722 314. THIS IS INSIDE UNDER THE DASH. 1506-6855 WAS ON TAG UNDER THE HOOD ON FIRE WALL? I KNOW NOTHING ABOUT THIS TRUCK. 128 H.P. DUELY. 5 WHEEL PLATE. ANY INFO WOULD HELP had some old firestone 36 x 4 1/2 tire with no skid(words) as tread pattern. in same trailer.
Sir Searchalot
Sir Searchalot
These don't seem to be AD or TF Vin numbers. If you would explain what the truck looks like. Big , small, pick up, flatbed, huge, COE, stake truck, 18 wheeler, old, newish,...If it is big and you have pics... put your question in "Big Bolts" section. The numbers you give may NOT be vin numbers. Here is the link to where to find them and how to decifer them, right here on the Stovebolt website. http://www.stovebolt.com/techtips/VIN.htm
Without more info, I would guess around 1928 or earlier. What are the casting numbers on the block? Pictures can help too. Post a picture of the cowl plate and the plate under the dash.
Have a look here Oldgmctrucks.com It seems that it may be a 1939 to 40 tractor, 350 series?
1951 1 Ton Completed
Post a picture and you'll get mroe help, but those aren't vin numbers.
My 46 GMC on Photobucket
POSTED PIC ON BIG BOLTS.
