0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i have an old gmc vin?? AFR722 314. THIS IS INSIDE UNDER THE DASH. 1506-6855 WAS ON TAG UNDER THE HOOD ON FIRE WALL? I KNOW NOTHING ABOUT THIS TRUCK. 128 H.P. DUELY. 5 WHEEL PLATE. ANY INFO WOULD HELP had some old firestone 36 x 4 1/2 tire with no skid(words) as tread pattern. in same trailer.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | These don't seem to be AD or TF Vin numbers. If you would explain what the truck looks like. Big , small, pick up, flatbed, huge, COE, stake truck, 18 wheeler, old, newish,...If it is big and you have pics... put your question in "Big Bolts" section. The numbers you give may NOT be vin numbers. Here is the link to where to find them and how to decifer them, right here on the Stovebolt website. http://www.stovebolt.com/techtips/VIN.htm
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Without more info, I would guess around 1928 or earlier. What are the casting numbers on the block? Pictures can help too. Post a picture of the cowl plate and the plate under the dash. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Have a look here Oldgmctrucks.com It seems that it may be a 1939 to 40 tractor, 350 series? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Post a picture and you'll get mroe help, but those aren't vin numbers. | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | | | |
