I am building a 53 pickup with a LT1 and 79 Camaro front clip. I bought some headers and they need to be bent or something to fit. Should I raise the motor mounts to raise the engine so the headers don't rub on the frame or bend the headers? Looking for a solution. I will also run into a problem with the steering.
Thanks for the advice
