Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TUTS 59), 45 guests, and 1 robot.
Topics128,009
Posts1,055,296
Members48,419
#855571 05/31/2012 10:57 PM
wondering it I could get one of you guys that has a Task force to snap a picture for me. Just like this one.
[IMG]http://i236.photobucket.com/albums/ff117/olddaze/photobucket-6633-1338500600718.jpg[/IMG]
I'm trying to get my drivers side cab corner fitted and it's not playing well with the inner cab corner. If I can get a good shot of a complete one and where it relates to the door bottom. I will know if I need to shorten the inner or drop the outer.
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #855581 05/31/2012 11:42 PM
does this help? or maybe this one? the rocker molding right below the door [face of the step] carries to a taper across the bottom of the corner
Flxible #855584 05/31/2012 11:47 PM
almost with the first one,needs to be alot closer.
olddaze #855587 06/01/2012 12:01 AM
best I got right now - the rocker molding on the step needs to match the same molding on the bottom of the corner, with a minimal gap between them and about 1/8" gap to the bottom of the door ... your pic almost looks like you're trying to work the corner without the step in place, I don't think that's possible, or at least pretty tough to get things right
Flxible #855638 06/01/2012 2:35 AM
Step goes in and out, it's not welded yet. I'm more concerned with the door gap/ending than the rocker. I've got some up/down wiggle room with the rocker.
olddaze #855658 06/01/2012 3:30 AM
the manual calls for minimum 5/32 gap all around the door, including bottom - so the door bottom is a bit over 1/8" above the step rocker, and the main concern will be that the bottom molding of the corner match the level of the step molding - that needs to be a straight line, and the door and step in place is the best reference so you don't wind up with a big gap door-to-step that the weather strip can't seal - or too tight a gap so the door won't close
Flxible #855659 06/01/2012 3:30 AM
