| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | wondering it I could get one of you guys that has a Task force to snap a picture for me. Just like this one. [IMG] http://i236.photobucket.com/albums/ff117/olddaze/photobucket-6633-1338500600718.jpg[/IMG] I'm trying to get my drivers side cab corner fitted and it's not playing well with the inner cab corner. If I can get a good shot of a complete one and where it relates to the door bottom. I will know if I need to shorten the inner or drop the outer.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | does this help? or maybe this one? the rocker molding right below the door [face of the step] carries to a taper across the bottom of the corner Bill | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | almost with the first one,needs to be alot closer.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | best I got right now - the rocker molding on the step needs to match the same molding on the bottom of the corner, with a minimal gap between them and about 1/8" gap to the bottom of the door ... your pic almost looks like you're trying to work the corner without the step in place, I don't think that's possible, or at least pretty tough to get things right
Bill | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Step goes in and out, it's not welded yet. I'm more concerned with the door gap/ending than the rocker. I've got some up/down wiggle room with the rocker.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the manual calls for minimum 5/32 gap all around the door, including bottom - so the door bottom is a bit over 1/8" above the step rocker, and the main concern will be that the bottom molding of the corner match the level of the step molding - that needs to be a straight line, and the door and step in place is the best reference so you don't wind up with a big gap door-to-step that the weather strip can't seal - or too tight a gap so the door won't close
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | |
