2 members (Hotrod Lincoln, Gdads51), 76 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
i have a 54 with a hydramatic. the column in the engine compartment is worn from age. the truck slips into gear very easily from Neutral. is there any fix to this at all? it is tight through every other point, even going into reverse. just curious if there is a fix for it.
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
I was having the almost the same problem, mine was slipping from 1-4 down into 1-3 position... I fixed it by adjusting the linkage and putting washers where they connect to tighten up the slop... It also took care most of the rattles in the linkage...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
On the bracket that clamps around the steering column that the neutral start switch mounts to under the hood, there are detents for each shift position. What happens is the rod right behind the shift lever is supposed to slide back and forth and lock into the detent positions. It dries up and binds so that the rod does not slide in and out smoothly as it should and you don't get the solid lock into each gear position.
