| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | i have a 54 with a hydramatic. the column in the engine compartment is worn from age. the truck slips into gear very easily from Neutral. is there any fix to this at all? it is tight through every other point, even going into reverse. just curious if there is a fix for it. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I was having the almost the same problem, mine was slipping from 1-4 down into 1-3 position... I fixed it by adjusting the linkage and putting washers where they connect to tighten up the slop... It also took care most of the rattles in the linkage...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | On the bracket that clamps around the steering column that the neutral start switch mounts to under the hood, there are detents for each shift position. What happens is the rod right behind the shift lever is supposed to slide back and forth and lock into the detent positions. It dries up and binds so that the rod does not slide in and out smoothly as it should and you don't get the solid lock into each gear position. | | |
