0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | I am rebuilding a '61 261 that will be going in a "stock" 37 chev 2 dr sedan. Do they make a 2 pulley groove damper for this engine? Any clearance issues with fan? Am thinking down the road of putting in IFS w/power steering hence the second pulley, or can I just use the single pulley for all? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | How long is the 261 compared to the 216? There's not much clearance in the front. My '38 coupe is pretty tight with it's 216.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Yes, a 2 groove pulley was available. It mostly came with added power steering. Also, used on the V8 version. Tiny has a legitimate question regarding clearance in your '37. I do not have clearance in my '50 AD for a 2 groove pulley.
Drew
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I used a replacement balancer with dual grooves cut in it. link to install article I got the balancer from Buffalo Enterprises. regards, Leon | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Thanks for the link! VERY helpful.
Jeremy | | |
