9 members (TexasJim50, TUTS 59, cmayna, TooMany2count, Hotrod Lincoln, Otto Skorzeny, Jay R, Forty9, 1 invisible), 91 guests, and 2 robots.
Topics128,134
Posts1,056,411
Members48,441
#855096 05/30/2012 2:03 AM
After having broken bolts drilled out of my exhaust manifold, installing new studs in both the intake and exhaust manifolds, installing the bright, shiny NOS choke thermostat in its home, and reassembling everything, I've found that...the choke rod does not reach the choke blade lever on the carb whenever the rod is pushed down as far as possible to fully load the thermostat coil, but is about 1½ inches short. The coil IS partially loaded and does barely close the choke when cold.
But do I need a longer rod to fully load the coil and ensure that the thermostat behaves as intended at all temperatures?
This is on my '69 C-10 ½-ton with an L6 250.
Darren
1969 Chevy C-10 Fleetside
After installing a new NOS choke thermostat on my exhaust manifold, I've found that the old choke rod does not reach the choke blade lever on the carb whenever the rod is pushed down as far as possible to fully load the thermostat coil.
The rod is about 1½ inches short. The coil is partially loaded and does barely close the choke when cold.
The questions is...do I need a longer rod to fully load the coil and ensure that the thermostat behaves as intended at all temperatures?
Darren
