1 members (Hotrod Lincoln),
76
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 43 New Guy | | New Guy Joined: Feb 2012 Posts: 43 | Has anyone tried the KBS products? In particular the frame coating products? Thanks! | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I used it on my frame and cab bottom. getting ready to use it on some other parts. seems fine. not sure there's any difference from por 15, little cheaper maybe. Most of this type of paint really needs 2 coats for it to do what if says it will. hope this helps. | | | | | Joined: Feb 2012 Posts: 43 New Guy | | New Guy Joined: Feb 2012 Posts: 43 | Are you happy with the finished look and durability?? Thanks. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Be sure you don't apply to areas that see direct sunlight as both the red/black fade in the sun. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Had a vendor selling it at a local swap meet a couple of weeks ago demonstrating it. He had me try to scratch it with a tool and it would not scratch,seemed really tuff.He said it was invented by the same guy that invented por15.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2012 Posts: 43 New Guy | | New Guy Joined: Feb 2012 Posts: 43 | Thanks guys! I think I might try it on the frame. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I found the contact sheet he gave me at the swap meet.
KBS Authorized Dealer CW Repair Denny at 660-287-0341 Willy at 402-699-2682 Shop# 402-339-1501 7866 Serum Ave, Ralston,NE 68127
Tim
