1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 16 New Guy | | New Guy Joined: Jul 2010 Posts: 16 | Hello,
I'm looking to rebuild or replace master brake cylinder I removed from my truck. I don't think it's original. Casting number is "6460268 64" and "1 1/4 DIA" and "DELCO MADE IN U.S.A.". On the end of the reservoir it's stamped "MODEL NO 361-F"
Please let me know appropriate re-built kit or replacement part.
Thanks.
-- Scott | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It would help to know what year and model you are referring too along with Chevy or GMC. Stock engine?
Drew
| | | | | Joined: Jul 2010 Posts: 16 New Guy | | New Guy Joined: Jul 2010 Posts: 16 | It's a 1942 3/4 Ton chevy (BL) pickup. The engine is 235 from 1960.
I also have a 1941 1 Ton chevy (YR) pickup and it has the same master cylinder; first 7 digits of casting number are the same.
The cylinder from the 42 does not have hole/threads for accepting the brake light switch. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | That casting number is 5450259 I have a kit for it $30.00 plus $5.35 shipping. I have more than one kit if you need more of them. Thanks!!! 1-262-392-2989 or [email protected]Marv. | | |
