| | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | First trip out ( tires are four years old) with radial tires and noticed a side to side shake around 37 to 40 mph. Above and below that nothing. Not real bad but you can definately feel it. Tire pressure is ok. Does it sound like a bad tire (belt)? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Almost sounds more like loose lugnuts. Generally, a belt separation will be felt at all speeds.
Bill Burmeister | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | I will check that in the morning. Thanks Tom | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Check your shocks. I had a 'wobble' on my '38. I replaced the king pins & checked everything for tight. All checked out good but the 'wobble' was still there. I fiddled with air pressure in the tires but no change. I finally put new shocks on and the 'wobble' went away. It felt like a wobble (side to side shake) rather than a bounce as you would expect from bad shocks but the new tube style shocks fixed the problem for me.
