| | | Forums66 Topics128,257 Posts1,058,017 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | I have a door that the threaded inserts are in bad shape where the hinge access panel screws to, does someone sell these so I can replace mine? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | My 52 chevy and my 53 GMC have inserts, 1/4X20 screws.You can get the captive nuts at a Ace Hardware the one by my house carrys them or you can order from McMaster Carr.You will have to drill out the old ones to whatever size the new ones need.
Pete | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Door is from a 47 to 50 and they take a 1/4 x 20 screw. They originally have a square hole that they are attached to. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Is there any way you could re tap the holes or are they rusted out? i had about the same problem on the 50 truck. Two of the holes on the passenger door were messed up. So I used a tap to re thread the holes | | |
