0 members (), 93 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Installed the pan tonight and as I was torquing the bolts to 6 ft pounds the gasket compressed. Just wondering if it "squishing" and curling this much is ok...
…Pic...
…Pic...
I don't have the corners down to 15 ft/lbs yet either....
Maybe I'm worrying to much - just dont want to warp the pan and destroy the gasket.
Mark
that's about how mine look. I usually just use a nut driver, and tighten until it feels tight... I know that's not exactly scientific, but seems to work for me with gaskets oil/side/tranny gaskets.
H Online: Content
You're WAAAAAYYYY too tight. Torquing a bolt against a part that's able to compress is a lost cause, no matter what the manual says.
You can replace the gaskets now, or wait until they leak. When you do, tighten the bolt just enough to remove any slack, then tighten approximately 1/4 turn further. Wait a few hours and recheck the bolts. If any of them turn freely, go about another 1/8 turn tighter. This procedure has worked for me for a little over 50 years, with very few leaks or distorted gaskets and/or sheeet metal.
Thanks Jerry - good advise.
