2 members (Shaffer's1950, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Rebuilding a '55 235 out of a car. It came with the pump where the pickup pivots. Also have a pump from a parts engine with the solid pickup. …Pic… Is there an advantage to one over the other? Anything I need to know about installing after a rebuild? Assembly lube needed in the pump shaft? Mark | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The important issue is the depth of the pick up screen in the pan. Use the one that properly fits your pan. No additional lube is needed. It will lube when primed.
Drew
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Good advice... these are the pans from each respective engine - the pivoting one on the left. I don't see much of a difference in clearance however.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Searched your web blog, but didn't see the pans. Very nice blog though.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have the oil gauge hooked up it will show you the pressure. You will be able to feel the drill load up too. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks Fred,
Got the bottom end completed last night. I've never read so many views and gaskets and sealants, and hopefully won't have to think about it for a while!
Really hoping to get paint on it this weekend, and then start it soon after!
Mark | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You probably already know this, but make sure you see oil reaching the valve train too. You don't want to find a plugged line later. And from personal experience; if a seal or plug isn't secure, your pants will get sprayed with oil. :mad:
Drew
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Good advice Drew,
I had planned on priming the system with the valve cover off for that exact reason.
I plan on starting it on an engine dolly (that I have yet to make using the guide on this site). That way (heaven forbid) that something leaks I'll be able to address it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Princess Auto has an engine dolly on sale right now. It looks perfectly siuted to a V8! | | |
