| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | I have a 55 2nd that has a 350 engine. It currently has the chicken leg engine mounts in the front of the engine and the bellhousing mounts in the rear. I would like to remove the front mounts to be able to mount the alternator down low to give a cleaner engine compartment. Which of the replacement mounts would be the best? http://www.ecklerstrucks.com/chevy-truck-tubular-engine-mount-crossmember-v8-1947-1959.htmlhttp://www.speedwaymotors.com/Chevy-to-1955-1959-Chevy-Pickup-Motor-Mounts,8473.html What are the advantages and disadvantages of each. Also, can I keep the bellhousing mounts or should I remove them and switch to a transmission crossmember? Thanks in advance. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I believe the type from Ecklers [which all the vendors carry, shop for price] will give you a stronger setup, adding a full cross member - also might be less interference with the e-brake mechanism .... and you don't need the trans cross member unless you go to an automatic
Bill | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Chassis Engineering recommends a crossmember-style front engine mount for frames wider that 25 inches (link). Your TF frame is 34 inches wide. The crossmember style mount will help to avoid frame twisting. regards, Leon | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I used a tubular style mount to fit a 455 Buick in my panel truck.
I modified a tube mount that was for a 460 Ford in a F100 truck! It allowed a nice low, set back & I was able to use the stock cast iron exhaust manifolds, too.
As the others here have stated ... it adds a bit of additional stiffness to the frame; esp. when putting in one of these torque monsters.
