1 members (baldeagle), 108 guests, and 7 robots.
Topics128,014
Posts1,055,328
Members48,419
#853403 05/23/2012 2:28 AM
I just re-did the front end. when I put the steering arm on and checked that the wheels turned i found that from the center position I can turn 1 complete turn to the right but I cn turn 2 complete turns to the left. What did I do wrong????????
evac34 #853449 05/23/2012 12:49 PM
Did you center the steering before you started putting things back together? What year are you working on?
yes I did center the steering wheel 1950 3/4 ton could I have put the steering arm from the steering box to the front end on backwards?
evac34 #853574 05/23/2012 10:52 PM
Leo Offline
Moderator
Moderator
I did that on my 53, pulled the steering column shaft back out of the steering box, made sure the gear in the steering box was centered, then re-installed the shaft.
