0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I just re-did the front end. when I put the steering arm on and checked that the wheels turned i found that from the center position I can turn 1 complete turn to the right but I cn turn 2 complete turns to the left. What did I do wrong???????? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Did you center the steering before you started putting things back together? What year are you working on?
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | yes I did center the steering wheel 1950 3/4 ton could I have put the steering arm from the steering box to the front end on backwards? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I did that on my 53, pulled the steering column shaft back out of the steering box, made sure the gear in the steering box was centered, then re-installed the shaft. | | |
