0 members (), 105 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
hello fellow enthusiasts. ..need help asap wiring my compressor. i am stumped as to the grounding :/ where exactly would i connect ground cable to compressor? have the breaker/panel part figured out smile using 3 wire. any and all input is appreciated.noticed two green screws inside compressor electrical box. the motor is grounded to one, the other does not have anything connected to it so im assuming would ground there?? thanks
1948 1/2 ton chevy pickup
1964 ss impala
1996 ss impala
8
8 Offline
Yep, you are correct, Green Screws in an electrical motor is used for the ground.
An elephant is a mouse built to government specifications.
sounds good. thank you sir.
alex
1964 ss impala
1996 ss impala
Moderated by  MNSmith
