| | | Forums66 Topics128,154 Posts1,056,840 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I'm about to reinstall the timing cover, can't find any reference in the manual to lubing the cam and crank gears up prior to first start.
Assembly oil? Grease?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | When you prime the engine with the oil pump some lubricant will come out the nozzle to lube the gears, but a little engine oil or lube is a good idea.
Drew
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks -
I thought as much, and I believe I manually turn the crank while priming as well.
Thanks for the confirmation. | | |
