1 members (Hotrod Lincoln), 212 guests, and 2 robots.
Topics128,090
Posts1,056,376
Members48,442
My cab is the original 1945 cab but because it is a military pole setting truck it has a sliding rear window in it that is installed in a frame with 14 bolts around the edge. The slider leaks and rattles and I want to replace it with a solid piece of glass and thats where the confusion begins. Civilian late 40's rear windows as far as I know just uses a rubber gasket to mount it not the more elaborate bolt system I have. I've seen pictures here in the gallery of the solid glass / 14 bolt frame system on a 40 GMC. My question is what years was the bolt frame used and is it possible to use the later forties gasket instead of it? Are the earlier frame pieces and gaskets available as repops?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
Mike, the '39 and '40 have the screw-in rear window frame, and I think I read that they went to the gasket in '41 (Somebody will be along to verify that.) Don't know if a gasket would work on something designed for the separate frame. The earlier frames come up on Ebay from time to time. I got a replacement gasket from Jim Carter, which requires a joint in it. When I replaced my glass, I was happy to find the original one piece gasket was still good, so I re-used it. And, of course, glass is readily available, too. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Almost sounds like the " civilian " glazing hole was filled with a " military " frame and slider glass ( still using the ( 14 ) bolt installation ? If so, I would think an original or repop exterior bezel and rubber gasket may work in place of the one you have. The rubber gasket can be cut to length, butt jointed, and glued with a " superglue " type product ( Steeles Rubber can give you the glue spec. )
1940 Chevy KC 1/2-Ton
Thank you both! I guess I won't know for sure what I have until I pull the frame off but a least now I'll know what parts to use when I find out what is under it.
-Mike-
