2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | What a [censored] night...
Been debating weather to go with the neoprene seal of the rope seal as part of my 55 reassembly. My 55 has machined surfaces and accepts the seal. I played with the rope seal at first but frustration got the best of me and I decided to go with the neoprene.
9pm last night...
Had it all assembled (crank, cam and timing cover backing plate, crank gear reinstalled and alligned) loctite applied - gasket sealer etc... carefully torquing - tripple checking everything... well - ALMOST everything...
Reread the neoprene instructions - darn... forgot to apply sealant behind the gasket... wow... how did I miss this?
So I pull the crank gear, pull the cam, pull all the mains.
Just as I'm about to pull the crank, I reread the seal instructions... I READ IT WRONG. The sealant just goes between the cap and block mating surface... %#^$ ... So I put it all back together again.
When I goto re install the crank gear, I put it on backwards... now gear pulling threads showing... its 11pm now and I'm tired...
Remove the cam AGAIN. Get to crow bars and gently work the crank gear off from both sides. Thank God I lubed the shaft. <tee hee> If came off easily and I reinstalled one last time.
I'll chalk it up to experience gained... the NEXT 235 should be a breeze! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Sometimes more than once. My next rebuild will go a lot easier because of the mistakes I made, too. It's the cost of an education.
1956 Chevy 3200
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | All makes me happy I did my training around 7 or 8 years old, kinda like most of the race car drivers now, only with the mechanics part instead and no teacher wasn't really dad's thing. Lets see that would have around 1960ish.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
