3 members (Bill Hanlon, WICruiser, Gray_Ghost), 182 guests, and 0 robots.
Topics128,089
Posts1,056,143
Members48,436
#852011 05/16/2012 11:51 PM
My passenger side rear brake light does not work. I have replaced the light assembly all together and still nothing. Is this normal for 1960? Thanks
Possibly in the rear wiring harness. No, its not normal.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Do you have turn signals? if so does it work on that side?
I had a problem like that on one of my trucks. I had to run a ground wire from the lamp assembly to the bumper to correct the problem.
The rear light buckets, the park lamp buckets & the head lamp buckets, need to have a good ground. Check all, to be sure you have good grounds, then check point A to point B, for continuity in the wiring.
