2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Tried to avoid asking - but in my big pile of bolts from engine assembly I can't figure out which fasten the thrust plate to the block. And it seems to be the only photo I didn't take...
Truckernix had told me it was a flat head (slot) screw... but I don't seem to have 2!
Anyone know the type and length?
Mark
I think the screws that hold the front plate on are flat head slot. If the plate does not have countersunk holes then you probably should be looking for normal heads. Somehow I think they may have a phillips head but I am not sure. I would put some medium locktite on them.
1951 1 Ton Completed
They are Phillips head 1/4"-20 x 3/4".
My Blog
Thanks guys!
Out to the heat...
