8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | I was wondering if anyone has checked out the book "How to restore your Chevy Pickup"? I'm trying to come up with a method for my madness. I'll start on a simple project, and find other problems I hadn't discovered.I get distracted way to easy. Lead time for parts is a pain, the local auto part stores are absolutely useless.
It's not the weight of the load, that breaks your back. It's how you carry it.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its a good book, written by Tom Brownell. Its a good starting point before you dig into your truck. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had the book right from the beginning. Some good info and helpful hints there. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Good book,I got one with the truck.
I do disagree about FLAPS I have a LEE and a CJC in my area and they are both very helpful,I've gotten alot of my parts thru them.
I like to have at least two things on the truck going at the same time.I'm working on a 53 GMC now.I just had the frame sand blasted and then I painted with Cassis Saver and at the same time I had some sheetmetal to finish on the cab that way there is no down time.I had to wait for the new pins and bushings for the springs so I worked on the cab.sheetmetal.I try to plan my next project as soon as I finish one that way I can order parts or start hunting them down so I have them when I start.
Pete | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | I think the method of madness is a lil differant for each person. I started with alot o soap, water, and a power washer! Then a GOOD visual inspection. Then a notebook to list missing or broken parts.(This also helps when pricing and/or swap meeting for parts.) Then come up with a plan of attack! Engine building and body repair at the same time (same space) leads to bad results on both ends! Grease and primer are not friends! I prefer to do all mechanical then all body. My shop is not big enough to do all at the same time. Just my thoughts. | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | Well, I'd say WE liked the book. Tom Brownell was a super nice guy and seemed to know his stuff. John had a blast working with him on the Big Bolts section. This Feature is an old one, but the book is still current. When I read a little of your post, I thought that would make a good Tech Tip -- how to plan the project. But maybe you are right, it's different for each person, each truck, level of ability, your shop -- and are you a type A or B personality?  Best advice: have fun at it at least! Good luck, Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Lead time for parts is a pain, the local auto part stores are absolutely useless. you need to find a better store. i use one NAPA store for 97% of my stuff. in six years and four trucks i have only been able to stump them on two items and both were last week which was a set up on my part  from my 1940 one ton. the most time i ever had to wait was three days and mostly if i call in the morning its there by 2 pm. for other truck stuff that napa doesnt carry its jim carter. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | During my working career, everything was planned to the nth degree. I find that working on my own project, be it a truck or whatever, I have an incredible sense of freedom. there are no schedules, no detailed budgets and I do it the way I want to do it. That is the way I enjoy the hobby. | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Just picked it up from my Local Library last week... about 1/3 of the way through and I've enjoyed it. I didn't know there was an update and that I had the old copy! What have they updated? Did they change thier suggestion of a 35mm camera to digital??? A section on bigger trucks interest me. Now that I know I like it, I'll probably seek out the updated version to buy so I can mark it up if I'd like as well... | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | And of course I ahve to support it as it references my home town of Palmyra, NY! | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I have both editions of the book and there's not a lot of difference. If my memory serves, and it seldom does, it's mostly in the photos. As far as the local parts stores, I've found that it all depends on the person behind the counter. All the stores have access to the same parts but some guys / girls / kids don't want to take the time to hunt for them. Most of the young guys working in these stores are only interested in hot rods, goofy wheels, purple lights, etc. Some of the older guys who grew up with these trucks like we did are a little more interested in keeping them on the road and will put forth a little more effort to get you the parts you need.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | Thanks everyone, yea its time to look for a different auto parts store. Just as jfnar states its kids that didn't know Chevy was even around in 49. I went in yesterday to find some little screw clips to hold the headlight can in the fender, you'd thought I landed on Mars. What I'm wrestling with is that do evrything in stages is the cost of duplicate parts. Take weatherstripping that needs to be glued in, if I don't do all body work before installing WS, I'd have to rip it out when I'm ready to paint. What about using RTV for the present, then going with gaskets when I'm ready to paint.
