0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Tried to avoid asking - but in my big pile of bolts from engine assembly I can't figure out which fasten the thrust plate to the block. And it seems to be the only photo I didn't take...
Truckernix had told me it was a flat head (slot) screw... but I don't seem to have 2!
Anyone know the type and length?
Thanks Mark
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think the screws that hold the front plate on are flat head slot. If the plate does not have countersunk holes then you probably should be looking for normal heads. Somehow I think they may have a phillips head but I am not sure. I would put some medium locktite on them.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | They are Phillips head 1/4"-20 x 3/4".
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks guys!
Out to the heat... | | |
