| | | Forums66 Topics128,034 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85254 03/04/2004 5:08 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Some time ago I've seen some really old electronic component dissassembled. I can't remember what it was, maybe it was a radio from the 40's. Back then, they used some kind of string with a continuing knot (half hitch?) along the full length of the run. I know it ain't original, but I was thinking of using this kind of arangement for securing my wires when I finish wiring my truck. Just in the engine compartment where it shows. It's probably time consuming, but it really looked cool, expecially if done real neatly. I'm not crazy about using plastic wire ties or plastic looms. Has anyone seen this kind of arangement? I just wanted it to look like it could have been done way back then. | | |
#85255 03/04/2004 5:36 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah, it's from the electronics world - that's the kinda cable tying I learned in the USAF way back - used a nice waxed nylon string that I still have a spool of - not the kinda thing usually found on a land vehicle, but it does look nice and is very functional couldn't say what it's called, nor explain, but stop in some day and I'll show ya!  doesn't take long if you get the hang of it, especially on short runs like under the hood - we hadta do things half the length of a B52 sometimes!  might be able to find the string at a leather shop or saddle makers, as it's like some they use Bill | | |
#85256 03/04/2004 7:26 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | Yeah, I learned the same style at Avionics school in the Marine Corps. (I worked on AV8As) The waxed cord is essential. I think a single half-hitch works because of the wax. I too don't really remember the exact knot. Actually, once you get the hang of it it runs a lot faster than setting a series of individual zip-ties.
Every 25 years I like to rebuild that 292 just for GP
#85257 03/04/2004 10:28 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So that is how that is done! I have seen that on a lot of aircraft, on display. I guess with all the vibration , you have to have everything super secured, without causing undue pressure. | | |
#85258 03/04/2004 3:16 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | The string is coated in bees wax as it is more sticky, there is two methods of wrapping the cord so it self locks, it's hard to explane how its wrapped, but if you check at the local librery and check out a book called the radio amateur's handbook, publish by the ARRL it shows how. I have a spool of the string about 6in long and 2in in dia, the bees wax gives the string an extra strength by keeping the fibers together. | | |
#85259 03/05/2004 2:50 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Steppenwood, is the string cut between the ties or continuous along the run? I think I've seen it continuous in old radio equipment and I don't think it's the same knot or string these guys are talking about. (we called both the process and the string "string tie" at the F-16 factory).
From your question it looks like you are talking about the continuous string. I think it was round and the "string tie" is flat. | | |
#85260 03/05/2004 4:26 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Cletis - what I did [still do] is continuous - starts w/ wrap and tie, then run string along the bundle about 3" min, 6" max [actually span of thumb tip when spread to pinky tip was max  ], hold there and put the roll of string around the bundle and back under that run, pull tight forward [where it'll hold well cuz of wax], repeat until the end is reached [of cable or roll of string!] - "good workmanship" meant the line of string nice and straight, spacing between wraps even, wires snugged in and nested well together, everything tight - some locations and larger cables got double wraps each time to lock better the technique allows for inspection of cables, lookin for sign of abrasion or heat damage, tracking any given color no matter where it might branch off, and individual wires could be removed and replaced w/o opening the cable - musta spent hundreds of hours trackin wires lookin for damage/ breaks, replaceing wires, tyin cable on C47, B52, KC135 - usually crawlin on yer knees Bill | | |
#85261 03/05/2004 8:22 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Bill, thanks for the info. Sounds like you did some real fine work. Do you know of any pictures of this kind of arangment on the internet. I'm really interested of doing my wiring like that (or try to). john.  | | |
#85263 03/06/2004 6:23 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Now I see. I've never seen it that way on an airship. All I've worked on are F-16s and F-111s. We tied off each knot individually and cut the string. I assumed all Air Force ships were that way. Our string is flat, yours looks round. Is it? | | |
#85264 03/06/2004 7:21 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Bill, thanks alot for taking the time to post those pics. I'm definitly gonna do that. Just in the engine compartment though. That'll look really nice, expecially if I do the knots about an inch apart. Ya think it's overkill? | | |
#85265 03/06/2004 3:58 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes Cletis, it is round, just the same as saddlemakers and sailmakers use , tho' leevalley has it in brown, ours was white - flat? ya sure they weren't given ya dental floss?  individual ties was prolly false economy - we sometimes had to cut into it, and never needed any 'replacement' string, just re-tie either side of the cut! John the advantage [and disavantage!] of inch apart is you'll be able to shape the cable as easy as if it was segmented, and it'll hold that shape - if inch is overkill, you know when it takes the wrong shape and won't do what ya want - make sure you find waxed string tho' as the wax is what makes it hold while yer workin it - might find the stuff they use for makin bow strings [as in bow n arrow] - good luck w/ it, and hope ya make it look nice! Bill | | |
#85266 03/06/2004 5:24 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | I have a spool of the stuff (750 yards) made by Gudebrod, inc Pottstown, Pa 19464 there web site is http://www.gudebrod.com/ | | |
#85267 03/06/2004 11:43 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Oh, a series of half hitches, the trick is to do it from the middle of the string run,no loose end. We used to do a lot of that in electrial construction, but lazy man tie wraps have mostly eliminated the string. | | |
#85268 03/07/2004 10:51 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | I know there was a trick of using a girth hitch (matching half-hitches) around the bundle and -- if you had to -- adding on a spare line or 2 for a new or replacement circuit. It could secure with a square knot, or that running lock knot no one can remember. I have used waxed dental floss, in a pinch and on the road, if I had to add-in or rework an under-dash circuit. I like the mint best.
#85269 03/07/2004 6:14 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Squeeze pics look good, but you are making the loops wrong, the string running parrallel to the wire should come out on on the underside of the loop, thereby locking each loop (not on the top) if you let go of the cord it will all unravel). Another method you make a loop (eye) and the cord continues through the eye locking even tighter. | | |
#85270 03/07/2004 7:36 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | steppenwood, this thread brings back memories. I ran wiring for telephone switch boards before solid circut swirch boards became the norm. We also used a flat wax sting to bumdle these. Made for a real neat bumdles. Start off with a bundle about as big as my wrist, it would start dropping wires at each relay, finally tapering down to a couple wires. Some of thse boards were 6/8 feet high and maybe 8/10 feet long. It looked complated to build but was really easy if you had good color vision. The engeeniers had it all laid out. All one had to do was follow the key sheet. Hated the job, cooped up inside, no real thinking needed to do it. But the end result was neat to see. Mike | | |
#85271 03/07/2004 8:27 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Albert - no - you're talkin of a different kinda "knot", and if I picture that right it'd require at least 1 or 2 additional movements, where what I do [was taught by USAF back then] is speedy and works fine, and the waxed cord is a good part of that - when pulled thru and "cinched" forward it holds quite well slomoe - I've seen those switchboard wire jobs at a salvage yard  hope it wasn't yer work!!  course, there's prolly planes in the "graveyard" near MT w/ my work still on'em! Bill | | |
#85272 03/07/2004 11:06 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Squeeze, the old wire switch boards I built were replaced by solid circut boards the size of a dinner plate. Now they are probably the size of a postage stamp, or smaller. Many old wire boards were sold overseas to developing nations. A lot of the old boards were stripped for the wire looms to salvage the copper and other presious metals. At the time the only thing I thought about them about was that they passed testing after I built them.  Mike | | |
