3 members (Otto Skorzeny, carbking, baldeagle), 110 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#852243 05/18/2012 12:45 AM
Hi Guys, I bought a 1949 Chevy 3800. It has the long bed, but not the 9 foot. I thought it was the 216 but after reading the posts I think it may have been replaced with a ? 235? The casting numbers
I read are 0541765 F54X. It has a 4 bolt valve cover, no oil filter, 6 volt wiring. So far it's a great driver, starts first time every time, runs smooth, shifts smooth. I couldn't be happier but I would like to tune it up but don't know what parts I need unless they are all close enough. I'm not a mechanic yet but want to learn to do my own.
Thanks, this is a great forum.
Mike
More helpful? information.
on the drivers side the casting number reads: 3835913 under this is GM 21. The engine is painted blue.
On the passenger side in front of the coil are the numbers cast in: 16B 913
241
570
hope this helps, Thanks again.
Mike
"F54X"
F= Flint plant
54= 1954
X= 235 with std clutch, 3100 1/2 ton
My Blog
Thanks for the quick answer. What do you think the lubrication type would be? I'll take this new information and revisit the forum looking for the particulars.
Mike49
This is a full pressure engine. It will not be drilled to supply oil for hydraulic lifters. Trucks used solid lifters.
My Blog
