1 members (baldeagle),
87
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 18 New Guy | | New Guy Joined: Nov 2011 Posts: 18 | Hi Guys, I bought a 1949 Chevy 3800. It has the long bed, but not the 9 foot. I thought it was the 216 but after reading the posts I think it may have been replaced with a ? 235? The casting numbers I read are 0541765 F54X. It has a 4 bolt valve cover, no oil filter, 6 volt wiring. So far it's a great driver, starts first time every time, runs smooth, shifts smooth. I couldn't be happier but I would like to tune it up but don't know what parts I need unless they are all close enough. I'm not a mechanic yet but want to learn to do my own. Thanks, this is a great forum. Mike | | | | | Joined: Nov 2011 Posts: 18 New Guy | | New Guy Joined: Nov 2011 Posts: 18 | More helpful? information. on the drivers side the casting number reads: 3835913 under this is GM 21. The engine is painted blue. On the passenger side in front of the coil are the numbers cast in: 16B 913 241 570 hope this helps, Thanks again. Mike | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | "F54X" F= Flint plant 54= 1954 X= 235 with std clutch, 3100 1/2 ton
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2011 Posts: 18 New Guy | | New Guy Joined: Nov 2011 Posts: 18 | Thanks for the quick answer. What do you think the lubrication type would be? I'll take this new information and revisit the forum looking for the particulars. Mike49
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | This is a full pressure engine. It will not be drilled to supply oil for hydraulic lifters. Trucks used solid lifters.
