0 members (),
142
Mod | | | Forums66 Topics128,132 Posts1,056,730 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 10 New Guy | | New Guy Joined: Mar 2012 Posts: 10 | My name is Paul Denicola and I just got signed up as a forum member. My brother-in-law, Elwood Bright, farmed for years in the Mississippi Delta ( D.E. Bright and Sons Farms, Doddsville, Ms.) and he gave me a 1946 Chevy 1 1/2 ton grain hauling truck. He parked it running in 1971 under one of his barns. We pulled it out in the fall of 2011, took the Army 2 1/2 ton truck body off the back of it and I trailered it to my shop in Rabun County Georgia. I am doing a complete rebuild. I am not going to do an "authentic original" rebuild but rather a rebuild that will make the truck safer and easier to drive and maintain. The truck VIN is 3 OS I 07809; 3 is St. Louis, Missouri plant; OS is 1946 (Interim Series), 1.5 ton, 160" wheelbase; I is September production and 07809 is the 6808th unit made in 1946 (07809-1001=6808). The model number is 4403 and it has the "Thrift-master"216.5 cu. in. engine. My first accomplishment was tackling the wheels and tires. I decided to go with modern one-piece welded wheels and radial tires. I purchased 6 Accuride item number 29667PG wheels and mounted Dynatrc ST990, 8R19.5 tires on them. I went to a local machine shop with a mounted wheel/tire and one of the brake drums with the hub on it and had them make spacer rings that will take up the space between the new wheel hub hole and the original truck hub so that the new wheel will still be "hub centered" and not move around on the hub when mounted. The tires are a few inches shorter than the originals but I was willing to make that trade off to get rid of the split rims and bias ply tires. My latest effort has been disassembly of the front cap and removal of the cab which is now complete. The truck is in great shape with the exception of a "locked up" engine. I purchased a 235 cu.in. replacement engine locally to get modern bearings and full pressure oiling. I also bought a spare transmission that was available with the replacement engine. My next project is to get the brake system rebuilt so I can remount the wheels/tires and move the chassis around easier. Wish me luck. I've gone through lots of cut-off disks getting those rusted bolts off and couldn't have gotten this far without the help of my brother Jim Denicola and friends Bill Newman and Jeff Reichmann. As soon as I can figure out how to post pictures I'll do so as I have been documenting this entire "journey." Thanks to all you "bolters" who have given me the information and encouragement to get this far. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Sign up for something like Flikr or Picasa. All of those things are free. Then post a link. We are looking forward to seeing your photos. | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | Welcome : Looks like your hitting the ground running with this project! I went with a insert motor on my 46 also. Nice to see anther Big Bolter in this part of country. I'll be watching for pics. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you're not done yet w/ rusty bolts, heating them red hot does wonders to the rust.
| | | | | Joined: May 2011 Posts: 5 New Guy | | New Guy Joined: May 2011 Posts: 5 | Can someone please help me know where I can find & buy these :
"6 Accuride item number 29667PG wheels and mounted Dynatrc ST990, 8R19.5 tires"
I have a similar BB & need some new wheels & tire options...
Thank you in advance.
Kieran K. Farmville, VA '47 ('46 Model/Art Deco) 1.5 Ton | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | Welcome to the site. Not sure how I missed your post when you first made it. I'm down in Athens and have a '46 OS as well. Do you still have your original rims/tires? I'm always on the lookout for spare parts. I'm keeping with the original 216 as well...I have two replacements now. One from a 1/2ton and one from a two ton I found later. I'll be using the 2ton as it has the larger transmission attached and was running when pulled recently. Keep us posted on your progress, and we love pictures. (and spare parts)  Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Welcome aboard and good luck on you project.
Ken | | |
