2 members (Joe H, Naturalthud),
196
0
Mod | | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 15 New Guy | | New Guy Joined: May 2012 Posts: 15 | So not sure if this is the right place for this.
I took a look at the plate on the driver side with the VIN and found some numbers and letters, and tried to figure out what they mean, tried using Google as well but no luck.
So can anyone of you guys help me out?
Here are the numbers
57 3600 SAJ31906 5800 LBS 2500 LBS 5000 LBS
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Domenique - I believe there was a period when these trucks were assembled someplace in your area - that SA may mean South Africa? otherwise the right drive trucks originated in Canada and were finish-assembled in Australia by Holden, so either way, you'll need to track down someone on that side of the world to learn much about your tag info
Bill | | | | | Joined: May 2012 Posts: 15 New Guy | | New Guy Joined: May 2012 Posts: 15 | I also thought that the SA meant South Africa. So in other words, the number does not say much! | | |
