0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#852092 05/17/2012 7:07 AM
So not sure if this is the right place for this.
I took a look at the plate on the driver side with the VIN and found some numbers and letters, and tried to figure out what they mean, tried using Google as well but no luck.
So can anyone of you guys help me out?
Here are the numbers
57 3600 SAJ31906
5800 LBS
2500 LBS
5000 LBS
Domenique - I believe there was a period when these trucks were assembled someplace in your area - that SA may mean South Africa? otherwise the right drive trucks originated in Canada and were finish-assembled in Australia by Holden, so either way, you'll need to track down someone on that side of the world to learn much about your tag info
I also thought that the SA meant South Africa. So in other words, the number does not say much!
