| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I removed the bed from my 55 2nd series 6100 and as I was cleaning the frame I from THESE NUMBERS stenciled on the frame. Apparently my truck was assemble on St. Patrick's Day 1955. Does anyone know what the other numbers mean? My truck was built @ the Oakland Ca. plant. SEE YA! Mark | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | At least the frame was assembeled that day. Paint the wrecker Kelly Green!
Be interesting to see date codes from trans, bell housing, radiator, rear axle and guage cluster and anything else that may be original to get an idea of build times. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I doubt that stenciling was done at the GM plant, more likely where ever the bed was added or maybe if the original purchaser was "corporate" it could be their inventory ID, a standard thing done with commercial buses and fleet trucks
Bill | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | og55, Does your frame show signs of being shortened? In 1955 "X" was the series designation for the 6500 trucks... What does it say below the date? Mike B  | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Hey guys, Thanks for the replies. Ricko, The frame and rear end are the only original parts on the truck.
red58, That makes sense I didn't consider that.
Mike B, The frame doesn't appear to be shortened. All the shackles and cross-members are still riveted and not bolted. There are no signs of cutting and welding either. Under the stenciled date it reads 2ND. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | During the change from 1st series to 2nd series the assembly plant may have needed to ID the new frames to keep things straight on the assembly line...grabbing at straws here...lol! Mike B  | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Hey Mike, That makes sense as well. That fact that it reads "2ND" makes me think it may have been done at the factory. If it was done where the bed was added as red58 suggested why would they care if it was a 1ST or 2ND series? Regardless I sandblasted the frame and repainted it. I made up new stencils and painted the date and numbers right back where they were. I just found them to be interesting. SEE YA! Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "2ND" meaning second series is an assumption, the 2nd series frame is very different than the 1st series frame, be pretty surprising if the factory had to label them to tell them apart  Bill | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Hey red58, Thanks for the 1st & 2nd series frame diagrams. Yes thinking "2ND" means second series is an assumption, but a reasonable one considering it's on a "2ND" series truck frame. Why do you think the company that put the bed on would label it that way? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | who knows? maybe they installed their "two-ND" bed on that date, with no idea that GM was calling the "new design 55" the second series ... if 2ND was put on by the factory, what does the X and the other numbers mean? do any of them match the vin? is the vin stamped on the frame member near the steering box? if so, the stenciling definitely wouldn't be factory, that apparently started with the 55 2nd's
Bill | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | I have seen parts with the shift designated in the part number, it could be the 2nd means the second shift of 3/17/55.
This may be a long shot but the frame could have been from a GM which had the S, T, X, and Y series rather than the Chevy with the J and N series. | | | | | Joined: Jun 2009 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 79 | I have a similar Stencil on my late design 63 k20 chassis, which till now was the only time that I had seen something like that. I traced and filled in the letters and numbers so that I could duplicate the stencil after I refinish the chassis. | | |
