0 members (),
40
10
Mod | | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85185 02/25/2005 3:26 AM | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | The wire harness I put in has a wire for an altinator. If I put one on my truck do I only hook that wire up and tape off the other two? The reason I am asking is that I put a 235 in and I am going to put an electric fan on the radator. My friend tells me that I will need to put an altinater on to run it . Hew says a genorator won't keep things charged.
Bart | | |
#85186 02/25/2005 5:21 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Educate yourself at MadElectrical.com -- that link takes you to his tutorial about alternators. If you're putting an electric fan in, you'll want to do what I did: [b]Wiring An Electric Fan with 2 Relays[/b]
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#85187 02/25/2005 5:25 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think your friend is full of prunes.
In reference to your wiring question, it depends on the alternator. Some have internal regulators and use 1 wire, others 3 wires. Others have external regulators and wire to them. | | |
#85188 02/25/2005 12:11 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I agree with Cletis,your friend dont know too much.A generator will work just fine. | | |
#85189 02/25/2005 8:26 PM | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | Thank you. I think I'll keep my genorator. | | |
#85190 02/25/2005 8:41 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Still not a bad idea to use a relay to run the fan.
But you don't need two of them if you can locate a single 60 or 80 amp relay. The common 30 amp relays might not be big enough.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#85191 02/26/2005 5:41 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The thing about using 2 relays is, if your fan turns on and off a lot the relays can wear out or burn out faster, with 2, they last longer ... don't heat up as much. See MadElectrical.com\'s explanation ... scroll down to ELECTRIC RADIATOR FAN SYSTEMS.
#85192 02/26/2005 7:14 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I run an electric fan on my 261. It draws 14 amps. I have it running off a thermostatic relay, wired directly to the ignition switch. I don't see the need for another relay, most of the current is drawn when the fan starts, which is provided by the thermostat. I have been running it that way for 2 years and haven't noticed any problem with the ignition switch.
Your generator is probably a 30 amp unit, which means that after running the fan (15 amps), the headlights (10 amps for 2 60W bulbs),and the ignition (5 amps), you have nothing left for the heater fan or the radio or charging the battery. If you are going to an electric fan you will want at least a 63 amp alternator.
#85193 02/28/2005 2:53 AM | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | I have an old 12 volt genorator from a sixtys grane truck. I don't know how many amps it puts out. I bought an electric fan wireing kit that has a relay and a thermostat. The thermostat is threaded and I don't know what it is supose to thred into. I'll get it all figured out though. I am thankful that you all are here to ask questions of. That link to the alternator site was very helpful.
Bart | | |
#85194 02/28/2005 3:46 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Bart, the sensor needs to go into water on your engine. I think a thermostat cover for small block V-8's fit the 235 six. Get one of those with the pipe threads in hole on side, which is for sensors and such on later year vehicles, from 70's and up. Seems like my Auto Zone has those in Chrome section hop-up stuff. Otherwise, you may have to put a tee in the heater hose somewhere, come off of it. It won't be so direct to heat though, and maybe not so good when not running heater in summer?
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#85195 03/01/2005 1:41 AM | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | I think I may move this post to the electrical bay -- not because I'm mad or it doesn't belong or any of that mickey mouse stuff, but because we have the foremost authority of antique vehicle electrical systems right here in the Stovebolt Page running that forum (Randy Rundle) and you stand a much better shot at getting the straight skinny right from the man himself if we pout it there. (Wow, that's got to be one of the longest sentences I've ever written...)
Ask Randy. In addition to what looks like a lot of good gouge already given here, Randy can either confirm or deny any of it.
Thanks for using the Stovebolt Page!
V/R John
~ One of many.
#85196 03/02/2005 5:54 AM | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | Thank you for your help. I couldn't reply because my dial up wasn't working very well. | | |
#85197 03/04/2005 8:41 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You actually want the temperature sensor in the radiator side of the thermostat. Otherwise the fan will be on most of the time. With it in the block the thermostat will keep the block temperature regulated pretty well until it starts to overheat. If you put it in the radiator or on the downstream side of the thermostat the fan will only kick on when the water in the radiator gets hot, so it will cycle better. This is the way my BMW is built.
The fan thermostatic relay I have is an all in 1 unit with an adjustment screw on the side and a thermocouple that you attach halfway down the radiator. The fan shuts off at highway speeds when the air flow is enough to keep the radiator cool, and kicks back on at low speeds or stopped when the radiator heats back up. It saves wear on the fan over just having the thing run when the block temp is over 180 degrees.
#85198 03/05/2005 2:40 AM | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | I found the thermostat houding with the extra hole for a thermostat. The hole is on the top so it would be on the radiator side. Thanks,
Bart | | |
