| | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I'm about ready to put my 235 back in my truck and after reading a post I realized that when I put the front cover on I didn't put one on. Is this going to cause an oil leak on the front through the crankshaft seal? If so now is the time to put one on. I don't think it had one on it before, because I kept all related parts on my bench ready to go back on after I got it back from machine shop. What do you guys think.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | It was probably left out on a previous reassembly. There will be more oil against the back of the seal, but none of the small block V-8's ran a slinger, and the vast majority of them don't leak. The V-8 seal is almost identical to the one for the 6. Jerry
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Thanks Jerry, I think I'll try it as is for now. I want to put this in and get it running this weekend. I'm not going to put the front sheet metal on yet so it will be readily accessable if it leaks.Larry
