7 members (J Lucas, Gdads51, 55shaker, Lightholder's Dad, wilbur53, Shaffer's1950, Eileen), 106 guests, and 3 robots.
Topics128,079
Posts1,056,297
Members48,441
1966 C-30 ... rear wheels touch each other in the middle with a heavy load. Tires inflated to 110 psi. What are my choices?
I would say there could be a few things to check. First check for proper tire size for the truck & that all 4 tires are the same size. Having worked in the tire business for several years I have seen people mix tires on duallys not a good thing. Second is to make sure that the rims are correct as well, if the offset of the rim is wrong that could be a problem even with the correct tire size. Make sure that all the wheels are the same as well.
Hope this helps...
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
The info you're looking for is here, page 45
http://www.accuridewheels.com/completeversion.pdf
•1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Dusty53
