3 members (Jay R, 5cameo8, Barry Martak), 145 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#851835 05/16/2012 3:01 AM
The clutch and pressure plate on the 47 appears to be stuck together. It had worked several months ago but now will not disengage. Is there any way to get at the clutch and pressure plate w/o removing the transmission?
It is probably rusted. You can have someone sit in the vehicle and step on the clutch while it is in hi gear. Or you can loosen all the bolts holding the pressure plate and try it.
Someone told me there may be an inspection cover on the bell housing. Is that true?
If there is, it will be top center and held on by two stove bolts. Remove the floor pan around the shifter for access.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
