0 members (),
97
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | OK, so about 2 miles from me, here's what I found. It looks rough. Floor boards have lots of holes, but the frame is solid. Not even sure the year. Guess is 1950? 1.5 Ton? Looks like a 216 and 4 speed. Thoughts? I'm sure I could grap it for VERY little cash. pic 1 Pic 2 | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Grab it! Whats better than one bolt? 2 I say. At least if you get it, it stands a better chance of not being scrapped. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Well, since they don't make 'em anymore, and if you have a place to put it and the necessary cash, how can you go wrong???????? If you never get around to fixing it up, some other bolter will be glad to get it, and maybe you make a few bucks and a new friend!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Anyone have an idea what year it is? Assume 1.5 ton.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | I'm new to this but no wing window means 47 or 48 right?
Tj | | | | | Joined: Nov 2000 Posts: 1,970 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,970 | No wing/vent windows through 1950.
I can't see if it has the gas tank filler in the cab behind passenger door. If it does, 49 or 50. If not, 47 or 48.
I agree - grab it if you can.
Professional Novice
