4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
Due to a bad back, I am being forced to remove the standard transmission crossmember on my 67 C30. Looking at a C50 I have, it has a removable standard tranmission crossmember. I realize that the transmission crossmember is the primary securing point on the 55 thru 72 GM trucks vs the engine mount from 73 up. If anyone has pics of a mod they made to make the trans mount removable would you please post some pics.
I used a crossmember form a 78 GMC 6500 in my 48 Chevy 6400.
http://rides.webshots.com/photo/2236622090080251109tywgjR
Needed to make channel pieces to bolt inside the frame and narrow the corssmember some.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I may have to go that route, but was hoping to find where someone had modified the existing crossmember. If not, I will and post my pics. I've got the game plan but haven't got to the point of trying it. (By the way, not that I have a need for it, but I have a roadranger ten speed out of a 78 gmc Brigadier. Does this tranny have the overdrive also?(I was under the impression that only the 13 speeds had the OD.))
Crusing in the Passing Lane
Most RR have Direct and OD ratios, tag on bottom should say RT- or RTO-, or turn input shaft and count output, direct should be far right, back, if OD, OD far right, foreward.
Moderated by  Dusty53
