Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (1 invisible), 156 guests, and 2 robots.
Topics128,290
Posts1,058,562
Members48,492
Hello,
I am in the process of rebuilding my 1956 235, and I have an extra part. This collar/spacer came in the box of used parts, and I'm not sure where it goes. It has a key hole, so I assume it goes on the crank somewhere. Any ideas?
http://i1206.photobucket.com/albums/bb458/vincejohnston/IMAGE_0151.jpg
http://i1206.photobucket.com/albums/bb458/vincejohnston/IMAGE_0141.jpg
Also, it looks like the center of my balancer is rusted. Are there supposed to be cuts through to the front? Do I need a new one?
http://i1206.photobucket.com/albums/bb458/vincejohnston/IMAGE_0161.jpg
Thanks for all the help,
Vince
that piece goes on the crankshaft, it,s an oil slinger. Get a shop manual or a motors manual and look through it. you will see were it goes.
Tommy
59 apache 1/2t
261 short stepside
The balancer looks rusty but it does not look too bad.
What are your referring to as "cuts through to the front"?
Just like this...
...click...
V
V Offline
Mine is a 1957 235, and yeah... the center of the balancer does actually look a bit off.
Is it possible someone tried to get the balancer off without a puller and caused that? I know that in my ignorance when I was first trying to remove my balancer, I ended up cutting deep inserts into the side of mine on accident, just like that. I ended up getting a new one. If the cuts looks to be caused by a chisel or something like that, and it worries you, you might want to consider a new one. I got mine for fairly cheap.
1957' Chevy Pickup
My welcome thread: Introduction and Story
My Album: 57' Chevy 3100 W/235
I have that same part. So that's an oil slinger and that's where it goes. Got to love this site.
Rick......
The notches on the center hole of the balancer are for the hand crank to insert into.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
