| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 20 New Guy | | New Guy Joined: Oct 2011 Posts: 20 | Hi, when I bought my 42 1/2 ton Chevy pickup it came with an extra drivers side front fender that was in better shape than the one on the truck and I never paid much attention to it, but it looked a little different to me, until I what to put it on and it is, it goes in more in the front,and the support bracket did not fit is the 42-46 1/2 ton fenders different than the 3/4 and 1 ton trucks | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | If the wheel opening radius looks larger, it's from a 1 ton or larger. If not, it may be GMC fender, don't know if they were different, but a GMC owner will be along to help!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | GMC fenders are the same as chevy, and 41-46 are the same. 1/2 ton and 3/4 ton are the same as well. It's possible your fender is from a 40 or from a heavier truck. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Can u post a picture ? '40 and earlier fenders do not have the headlight bucket attached to the fender. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Are you sure the fender is bent or twisted out of shape? Does it have the flat areas for the headlights? | | |
