| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | I have a '54 3600 with a 235 engine that was running. Began having some starting issues (rough start, wouldn't start) about 3 years. I got really busy with work/life, etc and had to let truck sit. Went and tried to start today, but same issue as when I left it.
Truck tries to turn over, but nothing. Put some gas in carb (per a friend) and still nothing. I am not a mechanic so any help would be appreciated.
Thanks and Peace.
Steve
Today is the best day of my life!!!
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Steve,
Might want to start with fresh gas.
Then put in new points, plugs, condenser. Give it a tune up, make sure the timing is right. Make sure you have a spark. If you don't know how to do these things, find someone who does. Maybe there is a fellow stovebolter nearby.
You will get it going.
Kurt | | |
