0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85146 07/17/2003 7:39 PM | Joined: Jun 2003 Posts: 16 Junior Member | | Junior Member Joined: Jun 2003 Posts: 16 | I plan on using a 1950 gas gauge sender in my tank, but a 1954 gauge on the dash. I know the '54 sender is a different design than the '50. Will the '54 gauge work with the '50 sender, or do I need to use a '54 sender? Thanks in adavance, guys!
Carl | | |
#85147 07/18/2003 1:15 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Yep, should be the same ohms. | | |
#85148 07/24/2003 3:22 AM | | Anonymous Unregistered | | Anonymous Unregistered | That set up will work with no problems. | | |
