0 members (), 66 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#851292 05/13/2012 7:36 PM
I've been driving about happily in my 1941 Chevy pickup for 3 years now and other than some basic servicing it's been reliable, fun and a real conversation piece.
http://www.dalbuie.com/41_Chevy_Diary_3_files/shapeimage_1.png
When I got it out last month (I put it away over the worst of the winter as we have salt on our roads!) the 6V battery was pretty weak and despite my best efforts I think it's time for a new one.
A 6V battery costs £120 but a 12V only £55 so my dilemma is should I convert to 12V given that I need to spend the money or should I stick to 6V?
I believe the starter is OK on 12V so as far as I can see I'll need an alternator, some bulbs and a 12V-6V convertor for the fuel gauge and heater fan.
What the the Pro's and Con's of the conversion - what would you do? Any advice welcome.
For those who believe, no proof is necessary.
For those who don't believe, no proof is possible.
41 Chevy
Dalbuie #851348 05/14/2012 1:15 AM
Sir Searchalot
Sir Searchalot
If you are happy with the truck, spend the extra 65 quid. Sounds like the last battery lasted at least 3 years?
bartamos #851354 05/14/2012 1:38 AM
Or, save 5 pounds and get this Optima 6v battery. I have had one for 7 years and another for 5 years.
I do not take them out of the truck for the winter and I do not even charge them after winter hibernation - they stay in the truck and start it right up in the Spring.
41 Chevy
Dalbuie #851435 05/14/2012 2:08 PM
Ex Hall Monitor
Ex Hall Monitor
I use a 6v Optima in my '38 as well.
Tiny #851875 05/16/2012 10:10 AM
Stick with the 6V in my apinion. But if you must here is a site to look at for 12v conversion
http://www.adchevy.com/techtips/12v_conversion/
good luck
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Dalbuie #851887 05/16/2012 1:02 PM
I also use a 6v. Optima. But even better, I keep an "intelligent" trickle charger connected if I'm not driving the truck. It will not overcharge the battery.
Beware that if you completely discharge an Optima battery, your battery charger will not charge it. You have to connect the Optima in parallel with another 6 v battery for an hour or two until it begins to take a charge. Then you can put the charger on it.
Kurt
Dalbui,
Here is the Tech Tip site for 12V conversion.
http://www.stovebolt.com/techtips/12_volt_conversion.html
Harold
Harold
