8 members (Chip O, Gdads51, J Lucas, Hotrod Lincoln, tclederman, Bill Hanlon, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I've had an antifreeze leak on the back of my 216 that I would like to fix. It's on my 46 1/2t. I'm thinking I've got a clutch kit, a tt ball gasket set so I thought I would fix it all at once. But as I started looking at it, I've got to pull the starter and the flywheel to get the bell housing off. But more alarming is if I wanted to pull the bell housing there is nothing to support the engine. So I have to disconnect the rear engine mounts and pull the engine. Am I looking at this correct? To replace the freeze plug ( expansion plug ) on the rear of the 216 I have to pull the motor in the process?
Help thanks Rick.. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you pull the toe and floor board you should be able to pull the bell housing without removing the engine. Just block the engine under the pan.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is how I did it with the motor in place in my 51. At the time I was replacing the toe board. rear frost plug replacement
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The old timers used to cut a hole in the firewall to replace it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It should be much easier on a 46 as the toe and floor boards are removable.
